فهد خليفة
فهد خليفة
Oct 14
Can I only use the GWM or Total oil recommended in the maintenance manual for the new 2023 5008? Can I use other common brands like Mobil, Shell, or Castrol? I saw a post from someone claiming to be a mechanic on the forum saying that using non-recommended brands will cause oil burning. Is that true?
سعود جعفري
سعود جعفري2024-10-16 20:27
Just use oil that meets the 0w30, C1 or C2 standards. The brand isn't that important, as long as the specifications are right.
أحمد شمس
أحمد شمس2024-10-15 06:42
The official website no longer sells GWM, mainly selling Castrol now. I don't get it.
عبد العزيز قادر
عبد العزيز قادر2024-10-15 03:24
It is not recommended to use others.
عبدالله سهيل
عبدالله سهيل2024-10-14 23:12
Recommend that the original manufacturer must meet C1 or C2 standards.
For a Mazda 3 with a 1.6L engine, you typically want to choose a high-quality engine oil to ensure optimal performance and longevity. Many users often recommend brands like Mobil 1, Castrol, or Shell. As for the viscosity, a common choice is 5W-30, but it's important to refer to your vehicle's owner's manual for the recommended specifications.
I just got an '11 Viano. Can anyone recommend a reasonable brand of motor oil? 🙏
What type of Shell oil should be used for a 2009 MDX?
Today, the maintenance technician suggested switching to Shell's Yellow Bottle motor oil, mentioning that Castrol's oil with cleaning features might cause more oil leaks. Has anyone used lower-quality oil before? Is it usable?
Car enthusiasts, for the 2017 MG GS automatic, which brand of transmission oil would you recommend?
What brand of engine oil should be used for the maintenance of a Peugeot 307?
Any recommendations for which brand and type of engine oil to use for a 2019 Kia Pegas that's run about 65,000 kilometers, as a second-hand car?
For the 2011 VW Touran with a manual transmission, it's generally recommended to use high-quality engine oil that meets the manufacturer's specifications. A popular choice is synthetic engine oil from brands like Castrol, Mobil 1, or Shell. Always ensure the oil meets the VW 502.00 specification for optimal performance.
What brand of engine oil is recommended for the 17 Middle East version of the FJ?
I'm planning to purchase a 5008 with a 1.6T engine soon. I'd like to ask current owners if it consumes oil, any maintenance issues, and what type of oil you're using.
Peugeot 5008
Peugeot 5008QAR 94,900 ~ 153,351Gasoline & Petrol
