محمد وسيم
محمد وسيم
Oct 9
What's wrong with my 2009 Volvo C30? It lacks power when cold, but it's fine when warm. Any ideas?
عبد العزيز خديجة
عبد العزيز خديجة2019-10-09 12:06
If the car lacks power when cold, you should check if the engine's coolant temperature sensor is malfunctioning. It's quite possible that a faulty temperature sensor is causing poor performance when the car is cold.
سعود خلوق
سعود خلوق2019-10-09 11:56
If your car feels like it's lacking power when cold, it might be due to carbon buildup inside the engine. Considering it's an '09 model, it's likely covered quite a few miles. You should also check if the fuel pressure is normal.
