avatar-image
عبدالله ق
Nov 17
Hi everyone, can the rear air vents be added to the Corolla Elite gasoline version? It doesn't come standard. Will it get hot?
How to adjust the rear overhead air conditioning to hot air in the 2018 Previa? Looking for expert advice.
The rear air conditioning vents are not blowing cold air?
Is there anyone else experiencing no hot air from the rear air vents in their Sharan?
When the air conditioning blows cold air for a while and then switches to hot air, and after being turned off for a bit, it works again before reverting to hot air, it's puzzling. Interestingly, this issue doesn't occur on rainy days or when the weather isn't too hot. What could be the cause of this situation?
Where is the rear air vent for the 40 series? There's none under the front seats either. [what]
Is there anyone who has added rear air vents for a small car? It's really hot in the back seat.
When I turn on the AC in my 2019 Taurus, the rear vents blow hot air. What could be the reason for this? Can anyone help explain?
Can the seats of the Supernova Pro be retrofitted with ventilation and an independent blower added for the rear air conditioning at the 4S dealership? It's too hot, and the air conditioning is really poor.
Hello everyone! Is it common for the rear air vents in the Outlander to have low airflow?
Toyota Toyota Corolla
Toyota CorollaOMR 6,000 ~ 10,100Gasoline & Hybrid
