حسن زيد
Dec 2
What format do you guys use for your USB drives? Mine keeps failing to read.
I bought a music USB online, but my car can't read it. What format should I change it to?
What formats does the 2017 Jeep Renegade support for USB drives and music files?
What formats of USB drives are supported by the 2017 Jeep Renegade?
4Hey guys, where do you buy your used cars?
5Bro, what's the reading on your coolant gauge? Mine's showing halfway. I have the second-gen unit.
6There could be several reasons why the music USB drive isn't responding when plugged into the USB port of your car or other device: 1. **Compatibility Issues**: Some car USB ports or devices may have compatibility issues with certain USB drives or file formats. Ensure the music files are in a supported format like MP3. 2. **File System Format**: Check if the USB drive is formatted in a compatible file system, such as FAT32 or exFAT, which are commonly supported by car audio systems. 3. **USB Port Problem**: The USB port itself might be faulty. Try plugging the USB drive into a different port if available. 4. **USB Drive Issue**: Although it works on your computer, there might be an issue with the USB drive that affects its performance in other devices. Consider testing with another USB drive. 5. **Device Settings**: Check the settings of the device you're plugging the USB into. Some settings might need to be adjusted to read external USB storage. 6. **Power Supply**: Ensure that the device has enough power supply to read the USB drive, especially if it's an older model or if there are multiple devices connected. Try troubleshooting with these suggestions to identify the cause of the problem.
7What formats does the USB interface support? I'm planning to use a USB drive to play lossless music, and I'm not sure if it supports APE format.
8Hey guys, is your app working? Mine keeps showing that it can't export data and nothing works.
9The 2020 model only has one USB port. If you plug in a USB drive to listen to music, you can't connect the car kit. The USB extension ports you bought aren't working, and the USB in the armrest cigarette lighter also doesn't support USB drive for music or connecting the car kit. Do you have any suggestions for using both the USB drive for music and the car kit simultaneously?
10Why can't my newly purchased USB drive be read and why does it show as not connected?
