نايف يزيد
Nov 22
Where do you insert the USB drive in the Changan CS55 Plus?
Hi, why is there no sound when I insert the USB? Thanks.
Can I plug in a USB drive? Where is the port located?
Hey friends, where do I insert the SD card in a 2012 VW Phaeton?
4How do you play USB music in this car?
5Where do I insert the SD card for the Vellfire's TV?
6How to insert a USB drive in a 2018 Mitsubishi ASX manual transmission fashion edition?
7Does the 2023 CS95 PLUS have a USB input port?
8Where should I insert the USB drive in the Hongqi HS7 to play music? I've tried both the slot under the dashboard and the one at the back, but it shows "USB not mounted". What should I do?
9Can the 2019 Changan Yuexiang Manual Comfort model use a USB flash drive?
10The 2020 model only has one USB port. If you plug in a USB drive to listen to music, you can't connect the car kit. The USB extension ports you bought aren't working, and the USB in the armrest cigarette lighter also doesn't support USB drive for music or connecting the car kit. Do you have any suggestions for using both the USB drive for music and the car kit simultaneously?
