علي كريم
Nov 13
The car door locks often have issues; sometimes the door won't open, and other times it won't lock. The fuel consumption is a bit high, but everything else is fine.
The left electric door of the Sharan doesn't auto lock. The switch works fine, but it doesn't auto lock at the end.
Do you sometimes have trouble opening your car door? Has anyone else experienced this?
For the 2009 Yuxiang, the driver's door often won't open. I have to lower the window and use the mechanical key from the outside several times. The other three doors are fine. Can someone tell me if this is a common issue with the old Yuxiang? [Facepalm]
4I bought a Kia Sportage in 2010, and suddenly the right rear door won't open. What could be the reason? It's not the child lock issue. Also, the door handle feels loose when pulled.
5My M7's electric right middle door isn't working. It opens a little, and if I press it again, it opens a bit more, but it won't close completely. Experts, what could be the reason for this?
6Recently, my fuel tank cap often won't open. Sometimes hitting it with my fist works. Any guidance, please? Thanks!
7Hey fellow car enthusiasts, does anyone else have issues with their Haval H7 keyless entry being inconsistent? Sometimes it works fine, but other times it's unreliable. Especially on rainy days, it often doesn't work.
8Hey car enthusiasts, have you ever experienced the trunk opening when you press the car key to unlock or lock the car? The sensor works fine for opening and locking the doors! But when I use the key to press the trunk button, it opens. What's going on??
9Why does the driver's door not open with the key unlock button after locking the car from the outside, while the other three doors can be opened?
10Why won't the right door open suddenly? Is it the child lock? Where's the child lock switch?
