أحمد إدريس
Nov 6
When the vehicle speed is around 105 km/h, the whole vehicle shakes severely, making it hard to reach above 110 km/h. However, when the speed is reduced to below 100 km/h, it gets better. What could be the reason? It's a rear dual-wheel Ousheng.
Does anyone experience noticeable vehicle vibration when accelerating between 95-110 km/h on the highway?
Iveco Ousheng, the new car was registered on June 1st. When driving above 110 km/h, the steering wheel starts to shake. Is it serious?
When the 2018 model 1.6 manual reaches 100 km/h, the whole car shakes. What could be the issue? At other times, it's fine.
4Fellow car enthusiasts, have you experienced slow shifting between the 6th and 7th gears with your 7-speed dry dual-clutch transmission? Mine doesn't shift to 7th gear even at 80 km/h and waits until it reaches 85 km/h. Is this normal?
5What is the top speed of your Eclipse Cross? When I floor the accelerator, the highest I can reach is 160 km/h, and it drops to 140 km/h on slight inclines.
6When driving above 80 km/h, there's a noticeable noise near the passenger side A-pillar. At higher speeds, like 120 km/h, the noise becomes even louder.
7Why does the car accelerate well at lower speeds, but when it reaches around 110 km/h, it struggles to accelerate further for overtaking? Even on a slight incline, it has difficulty gaining speed.
8For a 2013 Suzuki Swift, if you're experiencing a buzzing noise at speeds of 40 km/h and above, and the noise gets louder as you go faster, what can you do to reduce the sound? Any advice from experts would be greatly appreciated. Thank you!
9It sounds like you are experiencing a vibration issue with your vehicle, especially noticeable at certain speeds. After performing wheel balancing, the shaking became more pronounced between 100 to 110 km/h, even reaching the seats, but it disappears at 120 km/h. You also mentioned that at low speeds on uneven cement roads, there is a resonance from the engine compartment to the steering wheel. These symptoms might indicate an issue with the wheel alignment, tire condition, or suspension components. It would be advisable to have a professional mechanic inspect the vehicle to diagnose and resolve the problem accurately.
10When my car reaches a speed of 110, the steering wheel starts to shake. What's going on with that?
