خالد خالد
Feb 17
Does the Hyundai i10 have air conditioning?
When will it be released, and does the Toyota Aygo have air conditioning?
Does the Hyundai Accent have a tire pressure monitoring system?
Hey folks, does the 2015 model have an air conditioning filter? Some say it does, some say it doesn't. Has anyone replaced the air conditioning filter before?
4How did you solve the issue with the rear central air conditioning since the NV200 doesn't have central air conditioning?
5How much range does the C40 have with the air conditioning on in summer? And is the space very tight?
6The air conditioning internal circulation of the 2016 Hongqi H7 with the chrysanthemum logo is broken. How can it be repaired? Is it that one of the shafts of the air conditioning flap is broken? Do I have to replace the entire air conditioning assembly?
7Does your Santana's engine shake when you turn on the air conditioning for cold air?
8Why does the air conditioning blow cold air while driving, but not when stopped at a traffic light?
9Why does the air conditioning keep turning on and off at idle in first gear?
10Does anyone know where the air conditioning drain outlet is on the 2014 308?
