نايف خلدون
نايف خلدون
Dec 13
What should I do if the reverse camera image is blurry? Do I have to replace it? [Confused]
بكر عبد العزيز
بكر عبد العزيز2024-11-23 12:54
Clean the camera lens.
نايف مكتوم
نايف مكتوم2024-11-23 11:07
There's a camera at the rear of the car, go clean it.
My 2007 MDX's reverse camera is broken. Does anyone have a link to the original camera?
Does the 2012 Phaeton 3.0 Executive Edition have a reversing camera?
The spare tire compartment always has water in it, what should I do? Is it because the drainage hole is blocked or is it an issue with the wiring of the installed reverse camera?
I'm looking for advice from everyone. I want to install a reversing camera on my Mazda 2 and replace the original center console. I'm not sure if the reversing camera center console screens available online are reliable. Do you have any good recommendations?
Hello fellow car enthusiasts, I just bought a Navara. I noticed that the reverse camera image shows things a bit farther away, but in reality, they're much closer. Is there a way to adjust it to appear closer? I'm not quite used to it!
Why won't the panoramic image open? Clicking it doesn't respond, and it also doesn't switch to the camera when I put it in reverse gear. What's the reason?
Have you encountered a situation where the reverse camera image is missing the borders and only the image is displayed? How can it be restored to normal?
Hey car enthusiasts, have you noticed this? When you're reversing into a parking spot, the car looks straight, but on the 360 camera, it appears skewed. Before, when I parked using the 360 camera, the image showed the car was straight, but once I got out, the front was actually tilted to the right. And when it seemed straight from the outside, the image showed it was slanted.
I feel like the reversing camera image is not clear. Can I replace the camera individually?
When I suddenly shift to reverse gear, the 360 camera doesn't display. The screen isn't even black; it shows nothing at all. Do you have any idea what could be happening?
Hyundai Elantra
Hyundai ElantraOMR 5,700 ~ 9,891Gasoline & Hybrid & Petrol
