خالد سلطان
خالد سلطان
Nov 17
I just bought a GWM Grenadier 360, and I'm speechless. Would changing the camera improve things?
علي عبدله
علي عبدله2024-11-17 23:10
I almost cried when I saw the 360 yesterday. After all, I spent over 300,000 [I need some peace].
I just went to the 4S shop today, and I can't upgrade the car system. The original 360 camera is not clear and can't be calibrated. Regarding the transmission defect issue, the after-sales service at the 4S shop will apply to the manufacturer and get back to me. Also, I'm wondering if just changing the DSP will improve the original audio system since I don't like it. I'm considering the Pioneer 500A, which can connect directly with the original plug without installing separate loudspeaker wires.
Hey guys, I'm getting ready to change my car. I'm thinking of trading in my old GWM C30 and making a down payment of around 100,000. Any recommendations for a sedan in the 150,000 to 200,000 range?
Hello fellow car enthusiasts, I just bought a Navara. I noticed that the reverse camera image shows things a bit farther away, but in reality, they're much closer. Is there a way to adjust it to appear closer? I'm not quite used to it!
I bought a used Yizhi car and found a camera under the right side mirror. Does anyone know how to turn it on?
What's causing the shaking and jerking in the vehicle I just bought?
Hey car enthusiasts, have you noticed this? When you're reversing into a parking spot, the car looks straight, but on the 360 camera, it appears skewed. Before, when I parked using the 360 camera, the image showed the car was straight, but once I got out, the front was actually tilted to the right. And when it seemed straight from the outside, the image showed it was slanted.
I just bought a Subaru Forester 2.5 naturally aspirated. Is a fuel consumption of 13 with the air conditioning on normal? I would like to ask for advice from experienced users.
Why is it indicating that I need to change the oil again when I just changed it in March?
Has anyone upgraded their car's screen? 😁 I have the 2011 automatic base model and I'm just looking to see if anyone has done it before, just want to add a reversing camera.
I have a 2020 Touareg 3.0, and recently I've noticed that the 360-degree camera is getting less clear. Does anyone else experience this?
Toyota Granvia
Toyota GranviaOMR 16,900 ~ 20,900Gasoline & Petrol
