حسن بدر
حسن بدر
Nov 13
How do I switch to and from manual mode in the 2020 Intelligent Technology Edition? How do I switch between D and S modes? Do I need to press the button in the front?
Comments( 7 )
محمد يسار
محمد يسار2024-11-17 20:04
My 2021 model's manual gear shifting in S mode is broken, and I can't use the manual mode anymore. The warranty expired at the end of June, and I found out in October. The dealership said I need to pay 1200 for repairs. Forget it, I'll just use the D mode from now on. [I need some time to think]
عبدالله صلاح
عبدالله صلاح2024-11-14 21:38
In S mode, the gear automatically shifts up when the RPM exceeds 3000.
فهد حمدان
فهد حمدان2024-11-14 21:33
Just switch to S mode, then you can shift up and down! 😁😁😁😁
عمر جعفر
عمر جعفر2024-11-14 21:10
Can the S gear be directly engaged?
عمر جعفر
D - Automatic M - Manual E - Fuel economy
شعبان سلمان
شعبان سلمان2024-11-14 20:08
Please refer to the manual.
عبدالله نور الدين
عبدالله نور الدين2024-11-14 09:50
Can you switch to the S mode without pressing the button in front? Can you try it? When switched to S mode, you can manually shift up and down, but generally, it doesn't require shifting.
The gear shift light for the 150 isn't on. Could it be because a button wasn't pressed, like the ones for P, R, D?
When using the paddle shift manual mode in the HS with the S gear, do I need to press the brake pedal to change gears? In the past, when I drove a fully manual transmission, there was a clutch pedal. [Facepalm][Facepalm][Facepalm][Facepalm]
Why doesn't the 2020 Toyota Prado's central control screen automatically switch to night mode at night?
How do you switch between the advanced mode and normal mode of the Phaeton's air suspension? In the advanced mode, is the front lower and the rear higher when parked? [Facepalm]
How do I eject a CD from the CD player? I pressed the △ button, but it didn't eject.
How can I make CarLife full screen on the 2021 Intelligent Technology Edition?
How do I turn off the ECO mode and switch to the standard mode on a 2018 Fortuner? If anyone knows, please share some tips. Thanks 🙏
How can I prevent the headlights from turning on when I press the unlock button?
My 2018 Mitsubishi ASX suddenly has an issue with the multifunction buttons on the steering wheel. When I press the next track button, it switches to the previous track. Pressing the previous track button takes me to navigation or the radio. I replaced the Android head unit three weeks ago, and everything was working fine after the replacement. The issue just started today. I'm not sure if it has anything to do with the new head unit. Does anyone know how to fix this?
Hey car enthusiasts, quick question. When I switch from N to D while idling and press the brake, the car jerks a bit. It's a new car, is this normal?
GAC GS4
GAC GS4OMR 10,365Gasoline
