سعود معتمد
Nov 5
How much engine oil is needed for the 2020 1.5T GAC GS4 during maintenance?
أحمد مكتوم2024-11-06 12:25
4 liters
عمر جعفر2024-11-05 23:09
Four liters are usually sufficient.
What type of engine oil do you use during major maintenance?
How do you reset the maintenance indicator, and how much engine oil is needed?
How many liters of engine oil are needed for the maintenance of this car?
4How many liters of oil does a 1.5T engine need to be changed? Is it easy to do it yourself?
5How many liters of engine oil does a Lancer need for maintenance?
6How can I remotely start the GAC GS4?
7For the 2013 model of GAC GS5 with a 2.0L naturally aspirated engine, what type of engine oil do you recommend for maintenance?
8Which engine oil is suitable for the 1.5T engine B38A15A?
9How is the fuel economy of the GAC GS4 Max?
10How much differential oil needs to be changed?
