سعود لحود
سعود لحود
Oct 23
Is everyone experiencing the same issue with their GS4 Max when parking? When I'm parking, the shifting doesn't seem very smooth. If I press the brake too hard, the car stops abruptly, and if the control isn't good, it stops and starts repeatedly. With my Trumpchi M8, when I release the brake slightly, it moves forward gently. But with the GS4 Max, it's hard to control the speed at low speeds, as it stops and starts. Are other GS4 Max owners experiencing the same issue, or is there a problem with my car?
فهد حمدان
فهد حمدان2024-11-09 22:00
Just turn off the Auto Hold.
عماد علي
عماد علي2024-11-06 23:46
You can just turn off the auto hold.
محمد بندر
محمد بندر2024-10-23 15:31
The flagship 10.8 has been launched.
خالد غازي
خالد غازي2024-10-23 09:50
Too sensitive.
The car window with one-touch up/down feature, when closing, bounces back halfway and then stops. Has anyone experienced the same issue?
2019 Changan Yuexiang, after normal driving and parking, when trying to start the car again, the brake pedal is hard and the car won't start. What should I do? Urgent!
Why does it sometimes feel like the brake and accelerator are hard when I start the car, and other times they're soft? It feels uncomfortable to drive when they're hard.
Does the 2020 model of Jetour X70 have an automatic flashing function, like hazard lights, when braking hard at high speed?
Why is the stability control light on and the handbrake not working? Anyone else experiencing the same issue?
I'm driving a 2017 model 1.4T automatic 2WD luxury version. Last year, I replaced the recalled vacuum pump. When I used to drive it daily, I didn't notice any issues. Recently, I've been using the car less, and after it's been parked for a day or two, the brakes feel hard when I start it in the morning. I wanted to check if the vacuum is sufficient, so I tried coasting in neutral and after pressing the brakes a couple of times, they become hard. I want to ask fellow car owners if they've experienced the same situation. Thanks.
What does it mean when a yellow exclamation mark appears next to the start-stop light on the dashboard after sudden braking?
There is a "clunk" sound when applying the brakes to stop.
When the car starts normally and the brake pedal becomes hard after driving a certain distance, what could be the reason?
Will the 2024 JETOUR X90 PLUS automatically release the electronic parking brake when the accelerator is pressed during start-up?
GAC GS4
GAC GS4AED 99,000Gasoline
