سلمان كلثوم
سلمان كلثوم
Nov 6
What is the maximum tire aspect ratio that can be used on R19 rims? Will using 65 tires cause rubbing when turning the front wheels?
أحمد حارثي
أحمد حارثي2024-11-06 08:45
265/55 R19
Is there anyone else whose car makes a slight plastic rubbing sound when turning the wheel to the left?
Can the front wheels be replaced with 255/50/19 tires? Will it affect steering or rub against the inner lining?
Is the GV70's all-wheel drive truly full-time, and what is the front-rear power distribution ratio? I've seen some owners say it's not full-time AWD, mentioning that some modes require manual adjustment to four-wheel drive or allow switching to two-wheel drive. I'm a bit confused. Could someone explain the situation with this AWD system and how to use it?
Hey guys, isn't the 2019 Changan Yuexiang's wheel 14 inches? The tires are 175/65/R14. I'm thinking about changing the tires. What's the maximum size I can switch to? Thanks.
If we're talking about the SP model, is it necessary to choose 21-inch wheels? Would the 30 aspect ratio rear tires be prone to bulging easily?
When reversing and turning the steering wheel, there's a clunking sound coming from the right front wheel. Sometimes it also sounds like the tire is crushing gravel. What could be the issue? There's no noise during normal driving, only when reversing or turning the wheel to a certain angle. Is it due to worn-out control arm bushings or is it an issue with the steering rack?
What brand of tires should I use for the front wheels of a 453? The size 165/65R15 is indeed rare. Thanks.
Hi, what could be causing the steering wheel to make a buzzing sound when turning?
Can a 2010 car with a 1.6 automatic transmission and tire size 205/65 R16 also use 205/60 R16 tires?
What causes the steering wheel to make a noise when turning the shaft?
Haval H9
Haval H9EGP 1,659,234 ~ 1,804,207Gasoline
