رياض فهد
Feb 2
How can I change the brake pads on a 2006 Toyota Camry?
How do we maintain our Jimny? What engine oil should we use? How often should we change the 4WD oil? Where can we buy brake pads? ... Fellow car enthusiasts, please recommend reliable shops!
Looking for rear brake pads for Smart 453.
Can I buy rear brake pads?
4When the 2006 Legacy is in drive and you press the brake, there's a "doo doo" noise from the chassis, and the steering wheel and brake pedal vibrate. Sometimes it's mild, sometimes strong, and sometimes there's no issue at all. Could it be because the brake silencer pads weren't installed properly?
5How many kilometers do you guys usually change your brake pads? Yesterday, during maintenance, the technician said the brake pads need to be replaced, but I've only driven 40,000 kilometers. Shouldn't need to change them yet, right?
6Which brand of brake pads is good for replacement?
7How many kilometers should the brake pads be replaced on a Smart 453?
8What brand are the original brake pads, or can anyone recommend a good type of brake pads? Thanks!
9I've replaced the brake pads and discs on my Mazda6, and also changed the brake fluid, but the brakes still feel very soft and don't stop well. What could be the issue?
10Did you get your brake pads and brake discs replaced at the 4S shop? How's the quality? I just got mine changed today for 2500 RMB.
