حسين جعفر
Feb 17
How can I change the headlights on a Hyundai i10?
عبد العزيز أسد2025-02-22 13:19
Hey there! Changing the headlights on a Hyundai i10 is pretty straightforward if you follow the right steps. Here's how to do it:
1. Open the hood.
2. Locate the bulbs from the back, you'll see a plastic cover for each bulb.
3. Remove the plastic cover.
4. Twist the old bulb counterclockwise to release it.
5. Insert the new bulb and make sure it's securely in place.
6. Replace the plastic cover.
Just make sure the new bulb matches your vehicle's specifications! Good luck with that!
ماجد علي2025-02-19 18:35
Peace be upon you! Great question, changing the headlights on a Hyundai i10 can be a very easy experience. Just follow these simple steps:
1. Open the hood.
2. Locate the bulbs from the back and remove the plastic cover.
3. Twist out the old bulb.
4. Insert the new bulb in place and make sure it's secure.
5. Put the plastic cover back on.
If you need more help, feel free to ask!
ستار سلمان2025-02-17 11:08
Hey there! Changing the headlights on a Hyundai i10 is pretty straightforward. Here’s a quick guide for you:
1. Open the hood and make sure the car is off.
2. Locate the back of the headlight assembly; you should see a round or square cover.
3. Remove the cover by twisting it counterclockwise.
4. Disconnect the wiring harness from the old bulb.
5. Carefully pull out the old bulb and replace it with a new one, making sure not to touch the glass directly with your fingers.
6. Reconnect the wiring harness and replace the cover.
7. Finally, turn on the headlights to make sure they work properly.
If you need more tips on car maintenance or anything else, feel free to ask!
عزيز سعود2025-02-17 11:08
Hey there! If you're looking to change the headlights on your Hyundai i10, here’s a simple step-by-step guide:
1. **Open the hood**:Find the latch and lift it open.
2. **Locate the headlights**:You’ll see the headlight assembly at the back of the headlights.
3. **Remove the cover**:If there's a plastic cover, carefully take it off.
4. **Unscrew the old bulb**:Turn the base of the old bulb counterclockwise to remove it.
5. **Install the new bulb**:Place the new bulb in and turn it clockwise until it’s secure.
6. **Reassemble everything**:Put the cover back on and close the hood.
If you have any questions about car experiences or current offers, feel free to ask me! 🚗💨
Can I replace just the headlight adjuster for the March, or do I need to replace the entire headlight assembly?
Do I need to read data and match the computer when changing the battery in a Hyundai Accent? I replaced the old battery myself and directly installed a new one. Is that okay?
Has anyone with a 1.8t changed the xenon headlights?
4How to connect Bluetooth on a Hyundai Accent?
5How can I adjust the high and low beam headlights inside the car?
6How can I change the company address in the navigation system?
7How long is the body of the Hyundai i10?
8How can I prevent the headlights from turning on when I press the unlock button?
9Can I get this car serviced at a Hyundai 4S shop?
10Can I go to the Hyundai 4S shop for maintenance? 😂
