علي إبراهيم
Feb 17
How can I check the coolant level in my Hyundai i10?
How many kilometers can I drive after the fuel level warning light comes on?
If the turbo pressure isn't reaching the expected level and only reaches 0.8 in the 5th gear, how can you effectively check for leaks?
How to connect Bluetooth on a Hyundai Accent?
4Which coolant should I buy for the imported Koleos? I noticed today that the coolant in the reservoir is below the minimum line and I'm considering replacing it all. Could you advise on which coolant would be suitable?
5How long is the body of the Hyundai i10?
6How to check the transmission fluid dipstick: Is it normal for the fluid level to be almost one notch above the maximum hole when the car is cold?
7Can I get this car serviced at a Hyundai 4S shop?
8Can coolants be mixed?
9Where can I adjust the regenerative braking strength of the Aria? How many levels are there?
10Can I go to the Hyundai 4S shop for maintenance? 😂
