فاتح أحمد
فاتح أحمد
Feb 17
How can I increase the ground clearance of my Nissan Sunny?
جمال حسين
جمال حسين2025-02-22 12:07
Hey there! To increase the ground clearance of your Nissan Sunny, changing the springs is a great start. Just make sure to choose springs that fit your car perfectly. If you're thinking of adding body lift kits, be sure to check the weight your car's frame can handle. Have you ever tried this? I’d love to hear about your experience!
مستنصر عبدالله
مستنصر عبدالله2025-02-20 14:51
Hello! The idea of raising the car's height is awesome. But you need to be cautious, as increasing the height can affect the car's balance. I personally tried adding body lift kits, and the difference was noticeable! Are you considering doing that?
عبد لطيف محمد
عبد لطيف محمد2025-02-17 10:09
Hey there! So, if you're looking to increase the ground clearance of your Nissan Sunny, here are some steps you can consider: 1. **Replace the Springs**:You can swap out the original springs for longer ones, which might give you about 2-3 cm more ground clearance. 2. **Use Lift Kits**:Installing lift kits can raise your car even more, but make sure to pick a kit that fits the Nissan Sunny well. 3. **Bigger Tires**:Changing to larger tires could also boost your clearance, just ensure they fit the original rims. Before you dive into any modifications, keep in mind how these changes might affect your driving experience and comfort. Some users have found that using extended springs enhances performance on rough terrain without significantly impacting daily fuel consumption. If you need more info about other cars or buying tips, feel free to ask!
زايد عبد العزيز
زايد عبد العزيز2025-02-17 10:09
Hey there! If you want to increase the ground clearance of your Nissan Sunny, here are some steps you can follow: 1. **Replace the springs**:Consider swapping out the current springs for longer or stronger ones to lift the car. 2. **Use lift spacers**:Install lift spacers under the chassis for additional height. 3. **Adjust tires**:Using slightly larger tires can also help raise the vehicle's clearance. 4. **Consult a pro**:It's a good idea to check with a mechanic to ensure any modifications are safe and suitable for your car. Always make sure that any adjustments you make do not affect your car's performance or safety. Happy driving!
