تكريتي خالد
Feb 24
How can I reset the maintenance light in a 2006 Lexus LX 470?
فريدة نايف2025-02-28 13:16
Hi there! That's a really good question about resetting the maintenance light. I've tried this process before and I can assure you it works effectively. The steps are pretty simple and help keep your car in good condition! Don’t forget to also keep up with regular maintenance.
زين أحمد2025-02-28 10:34
Peace be upon you! Excellent question! Can anyone confirm if this method only works on the 2006 Lexus LX 470, or can it be used on other models as well? I think it’s worth a try!
سا مرعي سعود2025-02-27 13:48
Hey there! That's a great question. Resetting the maintenance light in a 2006 Lexus LX 470 is not as complicated as you might think. Just follow these steps:1. Turn the ignition on without starting the engine. 2. Press the "Odometer" or "Trip" button until you see the odometer. 3. Press and hold the accelerator pedal and the "Odometer" button at the same time for about 10 seconds. 4. Once the maintenance light goes off, you can release the buttons. Just remember, resetting the light doesn’t mean you’ve done the necessary maintenance!
صالح نايف2025-02-24 10:50
To reset the maintenance light in a 2006 Lexus LX 470, follow these steps:
1. Turn off the engine.
2. Press the "Start" button without pressing the brake pedal until the instrument panel lights up.
3. Press the "Trip" button (usually located near the speedometer) until you see "Maintenance" on the screen.
4. Use the "Trip" button to select "Reset," then press the "Enter" button.
5. A confirmation message will appear, choose "Yes."
6. Finally, turn off the key and restart the vehicle to check if the maintenance light is off.
This process should help you reset the maintenance light easily. If you have any other questions about car maintenance or technology, feel free to ask!
حارث فهد2025-02-24 10:50
Hey there! To reset the maintenance light in a 2006 Lexus LX 470, follow these steps:
1. Turn the ignition key to the 'ON' position without starting the engine.
2. Press the gas pedal three times within 5 seconds.
3. Turn the key off and then back on.
4. The maintenance light should be off now.
If this doesn't work, you might want to check the vehicle's system to ensure there are no other issues. Remember, resetting the maintenance light doesn't mean your car doesn't need maintenance; it's crucial to stick to your maintenance schedule to keep your vehicle in top shape.
How to reset the maintenance reminder on a car?
4How can I check the fuel consumption per 100 kilometers on the dashboard of a 2006 S40?
5How do I reset the trip meter after maintenance on a V40?
6How do you reset the maintenance light on a 2017 MG ZS?
7I've changed the oil. How do I reset the maintenance reminder?
8How to reset the maintenance reminder icon on the X90 Zilong? Can someone help, please? 🙏
9How do I reset the system after upgrading the MG HS Zebra system to the Venus system and after maintenance?
