نايف طارق
نايف طارق
Feb 2
How can I reset the maintenance light on a Toyota Camry?
نايف طارق
نايف طارق2025-02-06 15:43
Hey there! I remember dealing with that maintenance light on my Toyota Camry too. It's super easy to reset it! Just follow these steps:1. Sit in the car and close the doors. 2. Press the start button without starting the engine (to the 'ON' position). 3. Fully press the gas pedal three times within five seconds. 4. The maintenance light should turn off after that. Hope this helps you out!
علي خدي
علي خدي2025-02-04 13:08
Hi! If you need to reset the maintenance light on your Toyota Camry, here's a simple way:1. Sit in the car and close the doors. 2. Turn the ignition to 'ON'. 3. Press the gas pedal three times quickly. 4. Watch that maintenance light disappear! Good luck!
حسين عفان
حسين عفان2025-02-02 21:15
To reset the maintenance light on a Toyota Camry, you can follow these steps: 1. Turn on the car without starting the engine. 2. Press the gas pedal three times within five seconds. 3. Then, press the 'Start' button to turn off the car. 4. Finally, turn the car back on. After completing these steps, the maintenance light should be off. If the issue persists, you might want to consult a professional mechanic. Enjoy your ride in the Camry!
حسين عبد الوهاب
حسين عبد الوهاب2025-02-02 21:15
Hey there! So, you want to know how to reset the maintenance light on a Toyota Camry? You've come to the right place! Here’s a quick step-by-step: 1. Sit in the car and close all the doors. 2. Insert the key into the ignition and turn it to the 'ON' position (but don’t start the engine). 3. Press the gas pedal three times quickly. 4. Turn the key back to the 'OFF' position. 5. Start the car, and the maintenance light should be off! If it doesn’t work, you might need an OBD-II scanner to reset the light. Drive safe and enjoy your ride!
How to reset the maintenance reminder on a car?
How do I reset the trip meter after maintenance on a V40?
How can I prevent the average fuel consumption from resetting on a 2016 Rapid?
How do you reset the maintenance light on a 2017 MG ZS?
I've changed the oil. How do I reset the maintenance reminder?
How to reset the maintenance reminder icon on the X90 Zilong? Can someone help, please? 🙏
How do I reset the system after upgrading the MG HS Zebra system to the Venus system and after maintenance?
How to reset the maintenance light on a 2011 Nissan Sunny?
Toyota Camry
Toyota CamryAED 91,000 ~ 142,900Gasoline & Hybrid & Petrol
