عبدالله صعب
عبدالله صعب
Feb 2
How can I reset the maintenance light on a Toyota Camry?
حسين نور
حسين نور2025-02-06 19:34
Hi there! If you have any other questions, feel free to ask. I'd love to hear more about your experience with the Toyota Camry! Did you run into any other issues?
حسين حافظ
حسين حافظ2025-02-06 14:14
Hey there! Great question about how to reset the maintenance light on a Toyota Camry! I faced the same issue a few months back and was wondering what the solution was. From my experience, the steps I followed worked like a charm. It's always good to check the owner's manual too for extra details.
إياس حسن
إياس حسن2025-02-05 15:59
Hello! You can reset the maintenance light so easily. Just follow these steps: 1. Turn the ignition key to the 'ON' position without starting the engine. 2. Press the button on the dashboard until you see the 'reset' option. 3. Press and hold the 'settings' button until the light stops flashing. It's super easy! Hope this helps!
سلمان حارثي
سلمان حارثي2025-02-02 21:14
Hey there! To reset the maintenance light on a Toyota Camry, you can follow these steps: 1. Turn on the ignition without starting the engine. Just turn the key to the 'On' position. 2. Press the gas pedal three times within five seconds. 3. Turn off the ignition and then start the car again. If done correctly, the maintenance light should turn off. If it doesn’t, you might want to visit a certified service center to ensure there aren’t any other issues. Happy driving!
حسن قيس
حسن قيس2025-02-02 21:14
To reset the maintenance light on a Toyota Camry, follow these steps: 1. **Turn on the ignition**:Make sure the ignition is on but the engine is not running. 2. **Press the trip meter reset button**:This button is usually located on the dashboard. 3. **Navigate to settings**:Use the buttons to scroll through the menu until you reach the settings section. 4. **Select maintenance reset**:Look for the option that says "maintenance reset" and select it. 5. **Confirm the reset**:Follow the on-screen instructions to confirm the reset. Once done, the maintenance light should be off. Keep in mind that these steps may slightly vary depending on the model year of your Camry, so check your owner's manual if needed.
How to reset the maintenance reminder on a car?
How do I reset the trip meter after maintenance on a V40?
How can I prevent the average fuel consumption from resetting on a 2016 Rapid?
How do you reset the maintenance light on a 2017 MG ZS?
I've changed the oil. How do I reset the maintenance reminder?
How to reset the maintenance reminder icon on the X90 Zilong? Can someone help, please? 🙏
How do I reset the system after upgrading the MG HS Zebra system to the Venus system and after maintenance?
How to reset the maintenance light on a 2011 Nissan Sunny?
Toyota Camry
Toyota CamryAED 91,000 ~ 142,900Gasoline & Hybrid & Petrol
