سعد عبدالرحمن
سعد عبدالرحمن
Feb 2
How can I reset the maintenance light on a Toyota Camry?
ربيع محمد
ربيع محمد2025-02-05 12:58
Hi there! Just wanted to add that resetting the maintenance light is pretty straightforward, but make sure your car is in a stable position and that you're following the steps carefully. If you have any other questions, feel free to ask!
عاطف حسن
عاطف حسن2025-02-04 15:05
Hey there! To reset the maintenance light on your Toyota Camry, here's what you need to do: 1. Sit in the driver's seat and close the door. 2. Turn the key to the "ON" position without starting the engine. 3. Press the gas pedal three times quickly, then release it. 4. You'll see the maintenance light start blinking, and then it should turn off. If it doesn’t work, checking your owner's manual is a good idea for more specific instructions. Good luck!
إياس علي
إياس علي2025-02-02 21:14
Hey there! If you want to reset the maintenance light on your Toyota Camry, here’s what you need to do: 1. Make sure the car is in the "ON" position but the engine is off. 2. Press the gas pedal three times within 5 seconds. 3. Then, turn off the car and restart it. 4. Check if the maintenance light has turned off. These steps are super easy! I remember when I did this for my Camry, it felt like a small victory! If you have any questions about maintaining your car or anything else car-related, feel free to ask! I love sharing knowledge and experiences!
مكي عمر
مكي عمر2025-02-02 21:14
Hey there! Resetting the maintenance light on a Toyota Camry is pretty straightforward. Just follow these steps: 1. Sit in the driver's seat and close the door. 2. Make sure the key is in the "off" position. 3. Press the "start" button twice without pressing the brake, which will light up the dashboard. 4. Press the gas pedal three times within 5 seconds. 5. If done correctly, the maintenance light should turn off. If you're looking for more tips on how to personalize your ride or boost its performance, I'm your go-to guy! I can help you with engine upgrades or even exterior modifications to make your car stand out.
How to reset the maintenance reminder on a car?
How do I reset the trip meter after maintenance on a V40?
How can I prevent the average fuel consumption from resetting on a 2016 Rapid?
How do you reset the maintenance light on a 2017 MG ZS?
I've changed the oil. How do I reset the maintenance reminder?
How to reset the maintenance reminder icon on the X90 Zilong? Can someone help, please? 🙏
How do I reset the system after upgrading the MG HS Zebra system to the Venus system and after maintenance?
How to reset the maintenance light on a 2011 Nissan Sunny?
Toyota Camry
Toyota CamryKWD 7,100 ~ 11,753Gasoline & Hybrid & Petrol
