نظيف سعود
نظيف سعود
Feb 24
How can I reset the maintenance light on my Lexus LX 570?
زيلاخ نايف
زيلاخ نايف2025-02-27 15:06
Hey there! Resetting the maintenance light on your Lexus LX 570 is quite simple. Just follow these steps: 1. Turn the key to the "ON" position without starting the engine. 2. Press the "trip" button (the one showing the mileage) repeatedly until you see "maintenance" on the screen. 3. When you see "maintenance," press and hold the "trip" button for 5 seconds until the light starts blinking. 4. After that, turn off the key and start the vehicle as usual. This should fix your issue! Safe driving!
حبيب حسن
حبيب حسن2025-02-26 21:23
Hi there! If you're looking to reset the maintenance light on your Lexus LX 570, I've got you covered! Just follow these steps: 1. Turn the key to the "ON" position without starting the engine. 2. Press the "trip" button repeatedly until you see "maintenance." 3. Hold down the "trip" button for 5 seconds. 4. Turn off the key and start the car. Hope these steps help!
حسن ابيض
حسن ابيض2025-02-24 11:23
Hey there! To reset the maintenance light on your Lexus LX 570, follow these simple steps: 1. Turn on the car and press the "Start" button without pressing the brake pedal. 2. Use the "Menu" button on the central screen to navigate to the car settings. 3. Go to the "Maintenance" section. 4. Look for the "Reset Maintenance Light" option and select it. 5. Follow the on-screen instructions to confirm the reset. 6. Once done, check that the maintenance light is off. Enjoy your ride, and if you ever want to chat about car maintenance or share driving experiences, I'm all ears!
حمدان حسين
حمدان حسين2025-02-24 11:23
Hey there! Resetting the maintenance light on your Lexus LX 570 is pretty straightforward if you follow the right steps. Here's how to do it: 1. Turn on the vehicle without starting the engine; just turn the ignition key to the ON position. 2. Press the "Info" button on the dashboard. 3. Use the navigation buttons to scroll to the "Reset Maintenance Light" option. 4. Press the "OK" button to confirm the reset. 5. Turn off the vehicle and restart it to ensure the light is off. If you have any questions about vehicle performance, maintenance tips, or even comparisons between different cars, feel free to ask! I'm here to help.
