حسين عبد المجيد
حسين عبد المجيد
Feb 2
How can I turn off the maintenance required light on a Toyota Camry?
Comments( 6 )
نايف حميد
نايف حميد2025-02-07 14:49
Hey there! It sounds like you're dealing with the maintenance required light on your Toyota Camry. It's not too complicated! You can follow these steps to turn it off:1. Sit in the driver's seat and turn off the car. 2. Press the ignition button without starting the engine (ACC mode). 3. Quickly press the gas pedal three times. 4. Then turn off the car and start it again. If it doesn’t go away, you might want to check with a mechanic. Regular maintenance is key!
عمر علي
عمر علي2025-02-06 16:42
Peace be upon you! Have you tried the steps mentioned? I think you should also make sure everything in your car is working fine. If the steps don’t work, maybe there's a bigger issue.
حسن فاطمة
حسن فاطمة2025-02-05 10:04
Hi there! For the maintenance required light on the Toyota Camry, you should first check your oil and coolant levels. After that, you can use the method mentioned earlier to turn off the light. Wishing you safe driving!
سلمان زيد دين
سلمان زيد دين2025-02-04 21:08
Peace be upon you! If you're having trouble with the maintenance required light on your Camry, you can always rely on a qualified mechanic for help. These are good steps, but if the problem persists, don't hesitate to seek assistance.
نايف خدي
نايف خدي2025-02-02 21:15
Hey there! If you're looking to turn off the maintenance required light on a Toyota Camry, you’ve come to the right place. Here are the steps you can follow: 1. Turn on the ignition without starting the engine. 2. Press and hold the "trip" button until you see the odometer reading. 3. While holding the button, turn the ignition switch to the 'On' position (do not start the engine). 4. Keep holding the button until the odometer shows 000000. 5. Release the button and turn off the ignition. 6. Start your car again and check if the maintenance light is off. If this doesn’t work, you might want to check your owner's manual or visit a certified service center. I hope these steps help, and if you need any more tips about maintenance or repairs, feel free to ask!
عبدالله كم
عبدالله كم2025-02-02 21:15
Hey there! To turn off the maintenance required light on a Toyota Camry, you can follow these steps: 1. Sit in the driver's seat and close the door. 2. Insert the key into the ignition and turn it to the "ON" position, but don’t start the engine. 3. Press the gas pedal all the way down three times within 5 seconds. 4. You should see a message on the screen confirming that the maintenance light is off. 5. Now, start the engine and check if the light has turned off. If you have any other questions about cars or want to learn more about maintenance or features, feel free to ask! Also, always check your car's manual for the precise steps.
