سلمان سعود
سلمان سعود
Feb 2
How can I turn the maintenance light off in a Toyota Camry?
عماد أحمد
عماد أحمد2025-02-07 22:54
Hey there! To turn off the maintenance light in your Toyota Camry, you can follow these steps:First, turn the ignition on without starting the engine. Then press the gas pedal three times within five seconds. After that, start the car, and you should see the maintenance light turn off. But have you tried this method before? I think it's also important to perform regular maintenance to avoid future issues.
منتصر حسن
منتصر حسن2025-02-05 10:59
Peace be upon you! I found a good way to turn off the maintenance light in the Toyota Camry. You just need to follow the steps mentioned in previous posts. But do you think there could be a bigger issue behind this light coming on?
هارون عبد العزيز
هارون عبد العزيز2025-02-04 11:10
Peace be upon you! It seems you're having an issue with the maintenance light in your Camry. I personally faced the same thing a while back. After trying several methods, I found that using an OBD-II scanner was the most effective. I believe it would be helpful for you too!
انهايان نايف
انهايان نايف2025-02-02 21:13
Hey there! To turn off the maintenance light in your Toyota Camry, follow these steps: 1. Make sure the car is in the off position. 2. Press the start button without starting the engine (ignition mode). 3. Quickly press the gas pedal three times. 4. Start the car; the maintenance light should turn off. If the light stays on, it might be time for some real maintenance work. Remember, turning off the light is just part of keeping your ride in top shape! If you're interested in customizing your car or boosting its performance, feel free to ask me!
طيب سعود
طيب سعود2025-02-02 21:13
Hey there! If you want to turn off the maintenance light in your Toyota Camry, here are some easy steps you can follow: 1. Sit in the driver's seat and make sure all doors are closed. 2. Insert the key into the ignition and turn it to the "ON" position (but don’t start the engine). 3. Press the gas pedal three times quickly. 4. Then, turn the ignition off. 5. Start the car again. If done correctly, the maintenance light should disappear from the dashboard. But remember, if it keeps coming back, you might need to check with a service center to ensure there aren't any other issues. It's crucial to keep up with your car's maintenance to avoid future problems. I'm here to help you with any questions about maintenance or repairs!
