إلياس أحمد
Feb 17
How do I change the battery on a Hyundai i10?
Do I need to read data and match the computer when changing the battery in a Hyundai Accent? I replaced the old battery myself and directly installed a new one. Is that okay?
How to connect Bluetooth on a Hyundai Accent?
How to properly use the Polestar 2 battery, which is better between fast charging and slow charging, and do I need to regularly calibrate the battery? 😵
4How do I change the battery for the 2022 model car key? What type of battery does it use?
5Is there a tutorial for changing the battery? This morning I got a low battery warning. It's been about two and a half years since it lost power.
6I've changed the oil. How do I reset the maintenance reminder?
7How long is the body of the Hyundai i10?
8How often do you guys replace the battery, and do you stick with the original brand?
9Can I use the air conditioning while charging the AION on high-voltage charging? How can I do it without damaging the battery and the small battery? Thanks!
10Will changing the battery on a Cetus affect many settings?
