اشرف فهد
Feb 24
How do I check the oil level in a Lexus LX 570?
If the turbo pressure isn't reaching the expected level and only reaches 0.8 in the 5th gear, how can you effectively check for leaks?
How do I check the fuel consumption on a 2010 Acura MDX?
How do I check the remaining mileage for fuel?
4How do I check the fuel consumption on the GM8 steering wheel? How do I access it?
5I've changed the oil. How do I reset the maintenance reminder?
6How to check the transmission fluid dipstick: Is it normal for the fluid level to be almost one notch above the maximum hole when the car is cold?
7Which one is more suitable for family trips: Prado, Land Cruiser, or Lexus 570?
8How to check if the transmission oil needs to be changed?
9Does your 1.6 naturally aspirated engine consume oil too? Mine has only run about 90,000 kilometers, and after the last maintenance, I drove less than 2,000 kilometers before the oil light came on. When I checked the oil dipstick, it couldn't even reach the oil level.
10How to deal with oil burning? Today, while driving over a bump, the car jolted and the screen displayed a warning: "Low oil pressure, please stop." The warning flashed briefly and disappeared when I returned to a flat road. When I checked the dipstick, the oil level was very low. I just had maintenance done 1,000 kilometers ago. How should I repair this situation with a 1.6 naturally aspirated engine?
