عمر خير الدين
عمر خير الدين
Feb 2
How do I reset the maintenance light on a Toyota Camry?
سلمان معتمد
سلمان معتمد2025-02-07 13:37
Hey there! I totally get your frustration with that maintenance light on your Toyota Camry. I've been there too! To reset it, you just need to follow these steps: 1. Start the car and press the brake pedal. 2. Press the yellow button on the dashboard. 3. Turn the ignition key without starting the engine and press the button multiple times until you see 'Maintenance' appear. 4. Let it stay on for 10 seconds, then press the yellow button again. Hope this helps! If you have any more questions, just shoot them my way!
معتمد نايف
معتمد نايف2025-02-05 11:33
Hi! Just wanted to say that resetting the maintenance light on a Toyota Camry is super easy. I've done it myself before: 1. Start the car and push the brake pedal. 2. Press the yellow button on the dashboard. 3. Turn the ignition key without starting the engine and press the button several times until 'Maintenance' shows up. 4. Keep it on for 10 seconds, then press the yellow button again. I hope this helps you out, and feel free to ask if you have more questions!
نايف بوتفليقة
نايف بوتفليقة2025-02-02 21:14
Hey there! To reset the maintenance light on a Toyota Camry, just follow these easy steps: 1. Sit in the driver’s seat and close the door. 2. Turn the ignition on (but don’t start the engine) by pressing the start button or using the key. 3. Press the "Settings" button on the dashboard. 4. Use the buttons on the steering wheel to select "Maintenance." 5. Look for the option to "Reset Maintenance Light" and press it. 6. Confirm the action, and you should see that the maintenance light is reset! It's super simple! Enjoy your driving experience with your Camry, and always be ready for the next adventure!
علي طه
علي طه2025-02-02 21:14
Hey there! To reset the maintenance light on a Toyota Camry, follow these steps: 1. Turn the key to the 'On' position (without starting the engine). 2. Press the gas pedal three times within five seconds. 3. Then, start the engine. If you ever run into issues, consider enhancing your car's performance through some mods. For instance, adding a sporty exhaust system could significantly boost efficiency and overall performance.
