عبدالرحمن حجاج
عبدالرحمن حجاج
Nov 10
The rear door isn't properly closed, yet the car can still be locked. Is this a malfunction?
خالد حاتم
خالد حاتم2024-11-18 13:32
Just like the car doors, the latch has two positions. One position indicates that it's not fully closed, but you can still lock the car. The car doors work the same way.
حسين نور الله
حسين نور الله2024-11-10 10:25
Is it possible? I remember I didn't close my car properly, and if I locked it, the hazard lights would flash continuously.
أحمد نور
أحمد نور2024-11-10 08:48
Don't even mention Volkswagen, I remember many cars can be locked with the door open, and once you close the door, you can't open it. 😁
20
Why won't the electric sliding door close properly? I have to press it with my hand to get it to lock.
When driving slowly in the 150ltd, if you hear the sound of the electric pedal retracting or extending, it could be due to a malfunction or a sensor issue. Even if the car doors are properly closed, the motor sound might still be audible. It's best to have it checked by a professional to ensure everything is functioning correctly.
X70 stalls, and after closing the car door, it can't be locked with the remote.
The FJ keeps showing that the door is not closed. Pressing the lock button makes it beep continuously. Manually locking it works, but it still shows that the door is not closed.
Is it normal for the doors of a Mitsubishi Eclipse Cross not to close at -20°C and require extra force to shut properly?
The car battery is dead, how to lock the car doors? Currently, the mechanical key can only lock the driver's door.
Why do I feel that the soft-closing mechanism on the rear door is less sensitive than the front door? With the same amount of force, the rear door doesn't close properly. Do you guys experience this too?
Why does the car beep three times when starting, like the sound when a door isn't closed properly?
Does the 2013 Roewe have automatic window closing when locking the car, or can the windows only be closed by holding the lock button?
My 2021 Outlander's trunk suddenly won't open (can be opened with the emergency button inside). The lock button on the driver's side isn't working properly, can't lock the car. Any experts know how to fix this?
