صارم محمد
Feb 17
Is Nissan Sunny expensive to maintain?
اسماعيل سعود2025-02-22 22:46
Hey there! About your question on whether Nissan Sunny is expensive to maintain, I can say it's not too pricey at all. If you're looking for an economical and easy-to-maintain car, the Nissan Sunny is a fantastic choice. Just last month, I changed the oil and filters in my car, and it cost me around 300 AED.
If you’re planning maintenance, here are a few tips:
1. Keep up with regular maintenance every 5,000 kilometers.
2. Use original parts to avoid future issues.
3. Consult a reliable mechanic before making any major changes.
This way, your car will stay in good shape for a long time!
عبد الرحمن خالد2025-02-20 14:48
Hello! I’d like to add that the maintenance cost of the Nissan Sunny depends on the type of services you need. In my experience, most maintenance tasks were pretty reasonable.
Here’s some info:
- An oil change and filter replacement costs about 300 AED.
- Brake replacement can be around 1,000 AED.
If you have more questions, feel free to ask!
علي حرب2025-02-17 10:03
Hey there! Let me tell you about maintaining a Nissan Sunny. Generally speaking, the Nissan Sunny is considered to be economical in terms of maintenance. Based on maintenance data, annual costs typically range from $300 to $600, depending on usage and driving conditions.
One of the positive aspects is that spare parts are readily available and quite affordable in most markets. For instance, an oil change and filter replacement would cost around $50 to $100, while other routine maintenance like brake changes or battery replacements can run you about $200.
If you're looking for a car with low maintenance costs, the Nissan Sunny is definitely a solid choice.
نايف قيس2025-02-17 10:03
Hey there! When it comes to maintaining a Nissan Sunny, it’s generally not considered to be overly expensive. Typically, the annual maintenance costs can range from around 500 to 1000 SAR, depending on the type of service needed.
For instance, if you need an oil change, you can expect to pay about 150 to 300 SAR. If brake replacement is necessary, that might set you back around 400 SAR.
Overall, Nissan Sunny's maintenance is quite manageable compared to other cars in its category. Always remember to use genuine parts to ensure your vehicle performs well and maintains its quality!
Nissan Sunny 是几缸车?
What's the average fuel consumption for an automatic Nissan Sunny?
Is anyone selling a Nissan Sunny?
4Is anyone selling a Nissan Sunny automatic? 😊
5Is it normal for a 2003 Nissan Sunny 2.0L to run 300 kilometers on 34 liters of fuel?
6Is there anyone interested in buying a September 2011 Nissan Sunny automatic for sale?
7What is the normal RPM for a 2015 manual Nissan Sunny in fifth gear?
8How much is a June 2016 Nissan Sunny manual transmission worth now?
9Where is the temperature gauge in the 2011 Nissan Sunny 1.5XE manual comfort version?
