نايف لحود
نايف لحود
Nov 5
I'm considering getting the ES with a length of five meters. As a beginner, do you recommend it?
فهد أمين
فهد أمين2024-11-13 07:14
No problem.
2
سلمان ماجد
سلمان ماجد2024-11-06 17:31
If your driving environment is very crowded, it can indeed be quite inconvenient. [I need some peace]
عبدالله أزهر
عبدالله أزهر2024-11-06 16:15
Take your time to get used to it, it's a process. [Thumbs up]
رأس سعود
رأس سعود2024-11-05 14:15
Now even buying an A-segment car means it's about 4.4 - 4.7 meters long. Just an extra 30-40 cm, it's manageable.
خالد أنور
خالد أنور2024-11-05 12:05
Sure, everyone starts as a beginner before becoming an experienced driver. 😊
20
Friends, I'm considering buying a used MPV, and I'm torn between a 2012 NV200 and a 2016 JAC M3. Could you please share your recommendations?
Do you have a diagram of its length, width, and height dimensions?
I'm considering getting a Renault Koleos. How is this car?
I'm considering buying a gasoline version. What do you guys think?
I'm considering getting a manual Haima S5.
I'm considering changing my shock absorbers. Should I go for Bilstein B4 or Tein EnduraPro Plus? Or do you have other recommendations?
I have a Macan at home and I'm considering getting this one. Is the reputation of this car similar to the Macan? Are they both considered relatively affordable luxury cars? Do you recommend buying it? 🙏
I'm thinking about getting a used Jetta this year. Which model do you guys recommend? Thanks for the comments.
I've driven 100,000 kilometers and haven't changed the tires yet. I'm thinking of getting new ones. Do you have any recommendations? The original Kumho tires were just okay.
Lexus ES
Lexus ESEGP 2,666,260 ~ 3,714,120Gasoline & Hybrid
