نايف موسى
Nov 22
Could someone please tell me if the GAC M8 Leader Premium version with a modified electric tailgate can be controlled with the key? For example, can you press the key to automatically open the tailgate, or do you have to press the button on the tailgate to open it? Thanks, everyone. Also, can the button in the front driver's position be used to automatically open it without having to press the button on the rear door? Thanks a lot!
Comments( 9 )
If the hazard lights don't flash and the trunk won't open when you press the key, what should you do?
When the power tailgate of the 2018 Koleos only opens a crack and requires a second press to open fully, but closes in one go, how can this issue be resolved?
Hey guys, does anyone know why the trunk can be opened with the key but not by pressing the button?
4The trunk door of my X-Trail can't be opened or closed manually (I can hear a click from the manual button, but the door doesn't pop up automatically). However, it can be opened with the key. What could be the issue? Please help, thank you 🙏
5What should I do if the key of the 2022 HS7 can't open the tailgate, and the sensor can't lock the car doors? Thanks.
6Has anyone installed an electric tailgate? Can you recommend a brand? Thanks.
7Hey car enthusiasts, have you ever experienced the trunk opening when you press the car key to unlock or lock the car? The sensor works fine for opening and locking the doors! But when I use the key to press the trunk button, it opens. What's going on??
8Why does the driver's door not open with the key unlock button after locking the car from the outside, while the other three doors can be opened?
9How do you use the key to open the windows on the 2022 Kamiq? Thanks.
10How can the original key be used to remotely open the electric tailgate after converting to ePower?
