عبدالرحمن قيس
عبدالرحمن قيس
Nov 25
Hey car enthusiasts, today the dealership called and mentioned something about changing the spark plugs. What's up with that?
علي عمار
علي عمار2024-11-28 10:23
Replace the fuel injectors. In which month was your car manufactured?
Hey guys, at how many kilometers did you change your spark plugs? 😎
Has anyone changed the spark plugs on a 2018 manual MG ZS? Which brand is better? Any recommendations?
The 2022 Haval H9 is approaching 40,000 kilometers, and I'm not sure how much longer the original spark plugs will last. Fellow car enthusiasts, at how many kilometers did you change your spark plugs? What condition were the spark plugs when you replaced them? Thanks! ***** Also, I've clearly stated it's the Haval H9 and posted this in the Haval H9 section. Please make sure it stays within the Haval H9 circle and not other H9 circles. It's really tiring, you're quite something! *****
I've driven nearly 40,000 kilometers and I'm thinking about changing the spark plugs. Which model should I choose between Bosch and NGK? I saw a Bosch double platinum spark plug online. Is it necessary for this car to use double platinum?
The original spark plug failed after just over 10,000 kilometers. How about you guys?
Car enthusiasts, which brand of spark plugs do you recommend? Is everyone using Mitsubishi NGK single iridium spark plugs?
How often should the spark plugs in the 2019 GS5 be replaced? It's approaching 70,000 kilometers and hasn't been changed yet.
I'm thinking about changing my spark plugs recently. What brands do you guys use?
Hey guys, at 90,000 km, do I need to change the spark plugs? If yes, should I go for Champion or Mopar?
GAC M8
GAC M8OMR 12,700 ~ 18,864Gasoline
