حسين يزيد
Nov 29
What could be causing the two beeping sounds when closing the door on an MG 7? This wasn't happening before, and the windows are closed properly.
Why won't the electric sliding door lock properly? I have to press it with my hand to fully close it.
Why won't the electric sliding door close properly? I have to press it with my hand to get it to lock.
Sometimes, the middle door of my car closes halfway and then bounces back. Does anyone know why this happens?
4The FJ keeps showing that the door is not closed. Pressing the lock button makes it beep continuously. Manually locking it works, but it still shows that the door is not closed.
5Is it normal for the doors of a Mitsubishi Eclipse Cross not to close at -20°C and require extra force to shut properly?
6Why do I feel that the soft-closing mechanism on the rear door is less sensitive than the front door? With the same amount of force, the rear door doesn't close properly. Do you guys experience this too?
7Why does the car beep three times when starting, like the sound when a door isn't closed properly?
8When the window glass in the Outlander's cabin is lowered and the door is closed with a bang, what's going on?
9It would be great if the MG One could automatically close the car windows when locking the vehicle. I hope the manufacturer can upgrade the system.
10What could cause intermittent jerking at idle in a Jetta 7 after two years?
