علي زبير
علي زبير
Apr 29
What model of engine oil does the KIA Pegas use?
عبد العزيز آسيا
عبد العزيز آسيا2019-04-29 06:03
For the original KIA Pegas, it's generally recommended to use 5W-20 oil. In most cases, you should stick with 5W-20 for maintenance. However, after you've driven over 100,000 kilometers, you might consider switching to 5W-30. As for brands, major ones like Castrol and Mobil 1 are good options.
خالد سليم
خالد سليم2019-04-29 05:59
In winter, it's better to use 5W-30 oil, while in summer, you can switch to 10W-40. Make sure to use fully synthetic oil for better lubrication. It can be changed every 8,000 to 10,000 kilometers.
محمد فادي
محمد فادي2019-04-29 05:55
For maintaining the Kia Pegas, it's recommended to use 5W30 grade oil. You can choose between mineral oil or synthetic oil—either is fine. However, fully synthetic oil is generally considered better.
