سعود باهر
سعود باهر
Nov 22
After starting the car, the engine fault light comes on. I had it reset today, but it lit up again. I changed a tank of gas, but it's still the same.
سلمان رمضان
سلمان رمضان2024-11-29 21:32
Check for carbon buildup?
أحمد نعمان
أحمد نعمان2024-11-25 12:59
I don't know if it's an issue with the camshaft clamp, so I called the 4S shop to check it out.
خالد مطلب
خالد مطلب2024-11-25 11:43
Using the wrong engine oil can be a problem. This car's engine doesn't work well with many domestic oils. Last time, I used a domestic oil and had daily error reports. But after switching to Total oil, everything was fine.
أحمد جلال الدين
أحمد جلال الدين2024-11-24 20:57
I've been using Petrochemical 95 for 3 years, and never had a problem [thumbs up].
سعود زيد
سعود زيد2024-11-22 22:26
Use petrochemical or petroleum products. I had previously refueled at a small gas station, which caused an engine fault. After changing it, the issue hasn't occurred again.
The 2014 Zhiya's Blind Spot Detection (BIUS) system showed a fault warning in July this year, but today the fault disappeared and the feature is working again. What could be the reason?
Is there pressure in your ASX's fuel tank? When I open the fuel tank, there's air coming out.
Just had the 2019 automatic Rapid standard serviced and filled up with a tank of gas, then the engine fault code appeared. Has anyone else experienced this?
Even after changing the middle exhaust pipe, the fault light is still on. What could be the reason?
I've changed the oil. How do I reset the maintenance reminder?
Hey family, my Grand Cherokee suddenly started leaking water from the sunglasses holder today. Anyone else had the same issue?
Changan Alsvin, ABS and anti-skid faults, diagnostic shows left front wheel speed sensor fault. I replaced it, but the lights are still on. The diagnostic still shows left front wheel speed sensor fault, but all the data streams are there. The fault can be cleared, but it comes back while driving. What should I do?
Changan Yuexiang, ABS and anti-skid fault, diagnostic shows a left front wheel speed sensor fault. I replaced it, but the lights are still on, and the diagnostic still shows the left front wheel speed sensor fault. However, all the data streams are present. The fault can be cleared, but it comes back while driving. What should I do?
Today, I inflated the tire and reset the tire pressure, but it's still showing "monitoring" even after driving up to 25 km/h. I took it for a spin, but it didn't help.
Why is it indicating that I need to change the oil again when I just changed it in March?
Peugeot 408
Peugeot 408EGP 1,751,002 ~ 2,349,990Gasoline
