نايف مدرسي
نايف مدرسي
Nov 27
My car key's battery died. The first time I put it in the sensing area, it started, but two hours later, it wouldn't start even when placed in the sensing area again. Luckily, I was close to a key shop and got the battery replaced for 20 RMB. Can the sensing area only be used to start once? Please advise. Thank you.
سلمان رمضان
سلمان رمضان2024-11-29 21:27
It's not a one-time thing. If it doesn't start next time, you can try starting it with the sensor area.
محمد شهيد
محمد شهيد2024-11-27 18:07
I've had mine for over two years and it's still doing well. Plus, I have a spare key that I haven't used yet.
فهد كامل
فهد كامل2024-11-27 13:38
It's been 2 years, and the battery is still working.
عبدالرحمن ياسر
عبدالرحمن ياسر2024-11-27 13:10
Which brand of CR2032 battery costs 20 yuan and is so expensive?
عبدالله نادر
عبدالله نادر2024-11-27 10:46
So, does that mean we should buy spare batteries in advance?
My Previa's remote key won't unlock the doors, even after changing the battery. What's going on? Fellow car owners, can you please advise on how to fix this? Thanks a lot!
Where is the key sensing area on the 2016 model?
It seems like the car key is out of battery, and the car won't start.
The car wouldn't start just now, and the screen didn't light up. I couldn't unlock it with the key fob either, so I had to manually turn the car door open with the key.
The car key is out of battery, where is the sensor area on the car? Does anyone know?
Are there any 18-year Honda City owners here? Could you take a picture of your car's battery? After my car was repaired outside, it wouldn't start after a few days. I suspect the shop might have swapped my battery.
Has anyone replaced the key battery before? After I replaced the car key battery myself, I can remotely lock and unlock the doors without any issues, but the car won't start when I insert the key. The anti-theft system isn't connecting. Does anyone know how to solve this?
The battery of the JETOUR X95 is dead, and the remote key buttons are not working. After jump-starting the car, the emergency braking system activated. The car can drive normally, but the dashboard is only partially functional, as the idle speed and speed are not displayed. I tried to reprogram the keys because I have four keys, and the previously working key is not functioning anymore. However, I'm unable to successfully reprogram the key, and now the car won't start. Has anyone encountered this issue before? How was it resolved? This is the 2020 JETOUR X95 dual-clutch version.
Anyone knows where the key sensing area is on the 2017 GA8?
Hi fellow car enthusiasts, my 2021 Murano's remote key stopped working. I replaced the battery, but it didn't help. The dealership is quoting a high price. Can anyone advise where I can get a new one? Thanks!
Peugeot 408
Peugeot 408AED 114,900 ~ 150,000Gasoline & Petrol
