avatar-image
خالد جم
Oct 20
What dash cams is everyone using? The hidden dash cam that came with the car from the 4S shop has some noise issues, so I'm considering replacing it.
I just got the 2021 luxury version of the GV80. I'm wondering if I need to apply a front windshield film and window film. Also, for a dash cam, which type can be hidden without needing wiring? Looking for some expert advice.
Hey everyone, I'm considering a 2010 registered 1.4TT Scirocco. Is it a good choice or does it have any hidden issues? Any advice would be appreciated, thanks!
I'd like to ask everyone what brand of dash cam you're using. Which model is suitable for the GV70?
Are there no more 4S shops now, so should I go directly to a repair shop for maintenance?
Just got a used 2019 Haval H9 on 11.20. The navigation isn't working (failed to start), and I haven't figured out how to use the dash cam. Hope some helpful car enthusiasts can offer some advice.
Why is maintenance at 4S shops so expensive, folks? Can I get maintenance done outside of 4S shops?
Should I replace the battery at the 4S shop or do it myself? I'm torn.
I just got my G70. How did everyone install their dash cams? Did you run the wires through the A-pillar and then route them under the center console to connect to the cigarette lighter?
The dash cam on my 2021 Outlander sometimes has a black screen upon startup, and I have to turn it on manually. Is it about to fail? What model of dash cam would be suitable to replace it?
This car has been abandoned by the manufacturer, and Dongfeng Fengxing is about to go bankrupt. What should everyone do if they can't find a 4S shop? Do you usually get maintenance at the 4S shop?
Exeed  Exeed RX
Exeed RXAED 149,999 ~ 169,999Gasoline
