avatar-image
سعود إدريسي
Oct 31
Complaints about the Sonata 11's wipers: they're noisy and don't clean well. The headlights aren't bright enough either. Is there a replacement available? Any recommendations?
حسن ميثا
حسن ميثا2024-11-07 07:13
Except for the top configuration, which has projector headlights, the headlights on this car are the most basic reflector type, and the performance is indeed average.
عبد العزيز طه
عبد العزيز طه2024-10-31 17:59
It's also possible that the wiper blade pressure is too high. Check if the wiper rubber strip is pressed down.
علي ماجد
علي ماجد2024-10-31 12:38
Listen carefully to identify which pin is making the noise. You can unscrew that pin and flip the rubber strip to the other side.
I feel like the headlights aren't bright enough, especially the high beams. Do any fellow car enthusiasts know of any parts I can replace them with?
Hi everyone, I'm looking to upgrade the halogen headlights on my 2014 Yizhi to LED ones because they're not bright enough. Any good recommendations? Thanks!
Does anyone feel that the headlights of the Yaris X are not bright enough? Has anyone modified the headlights, and are there any compatible headlights available now?
Is the brightness of the GV80's headlights not sufficient? 🙏🙏🙏🙏 Thanks a lot.
Hey folks, are your car lights bright enough? I'm thinking about changing mine because they don't seem bright, but it looks like I have to remove the entire headlight to do it. Has anyone done this before? Any advice?
I only replaced the front two tires, not the rear ones, and they're from two different brands. The tread patterns are quite different, and the load capacity and speed ratings aren't the same. Is this okay? Is there any risk? Do I need to replace the rear tires as well?
Can the daytime running lights be replaced separately? I modified the headlights, and it seems like the daytime running lights got damaged; their brightness isn't enough. It's a 2009 model.
Recently, I feel like the brightness and range of the H2's headlights are getting worse. Has anyone replaced the front headlights? Any guidance? It's a 2018 automatic model, with 60,000 kilometers.
Could you recommend a car light? I feel like my current ones aren't bright enough.
How can I adjust the low beam height on my H7? They're too low. Also, how do I use the headlight cleaning system? Waiting for some advice from fellow car enthusiasts. 🙏
Hyundai Hyundai Sonata
Hyundai SonataAED 76,000 ~ 124,000Gasoline & Hybrid
