محمد نبراس
Nov 18
I have a question about the new Sonata's air conditioning. Does the temperature only go up to 27°C? It got colder today, so I turned on the AC and found it couldn't go higher than 27°C. My previous cars could display up to 30°C. 😂😂 Also, I've set the fan speed to almost maximum, but only the vent under the central screen is blowing air. There's hardly any air from the driver, passenger, and rear vents. 🤔 Is it supposed to be like this, or is there something wrong with mine? 🤔
For the 2017 GWM Haval model with 110,000 km, if the air conditioning isn't blowing air until the fan speed is set to maximum, or the AC needs to be turned off for a few seconds before air comes out, there might be an issue with the blower motor or the air vents. It's best to have a professional check the blower motor and the vent system for any blockages or mechanical issues.
Hey fellow car enthusiasts, my Lancer's fuel gauge is below the red line, but the fuel light isn't on. I can only fill up 37 liters, but isn't this supposed to be a 50-liter tank? Has anyone tested this?
4When I floor the accelerator on my 2.0T model, the RPM only goes up to 3000 and won't go any higher. Is this normal for everyone else's car too?
5What car control app is everyone using now? 🤔 My app stopped working! A few days ago, I tried to use it to turn on the air conditioning, but nothing happened. And today, I found that I can't even log in—no response at all. Is this car brand going bankrupt?
6For the 2017 model, if the central control air conditioning vent is weak and you hear a loud noise from the air conditioning even when it's on maximum, but there's not much airflow, how can this be resolved?
7Does anyone know if the center console screen frame panel of the 2016 model is the same as the 2012 model? I only found the panel for the 2012 model, the one with the air vents.
8The co-driver's window of the Mitsubishi Eclipse Cross can only go up but not down, and the main driver's switch can control the other three windows except the co-driver's, which can only go up but not down. The co-driver's switch also only allows the window to go up but not down. What could be the reason for this?
9The air conditioning in my 2019 model Yueshang only blows air towards the front windshield, while there's no air coming from the center console or side vents. Does anyone know what might be causing this issue, and is it complicated to repair?
10Hello everyone, my E2 used to charge up to 43 kWh, but now it only goes up to 30 kWh. What's going on? It's a car from October 2019 with 190,000 kilometers.
