avatar-image
محمد ممدوح
Nov 5
Is there a solution for the ambient light issue? I went to the dealership once, and they just restarted it, but it didn't fix the problem.
طارق فهد
طارق فهد2024-11-14 16:45
The damn ambient lighting doesn't make a difference whether it's on or off.
عبدالرحمن هلال
عبدالرحمن هلال2024-11-09 10:12
"I want to be alone for a while."
علي مدرسي
علي مدرسي2024-11-08 15:45
Anyway, I haven't encountered this situation with my 1.5 Pro.
Has anyone experienced the central control display screen constantly restarting? My 2017 Multivan started having this issue after changing the battery. Any good solutions?
Is there a problem with the car if the auto start-stop system, once activated at a red light with a deep press, automatically reignites due to the long red light duration and causes noticeable shaking?
MG ZS has run over 30,000 kilometers and is experiencing exhaust pipe issues, misfires in cylinders one to four, and unstable idling. Is this an internal engine problem? Is it very serious? Kind of regretting buying an MG. Went to the 4S dealership today for after-sales service, and the problem is still being addressed [frustrated].
I experienced a similar issue with my steering column making noise and feeling stuck. The dealership suggested replacing it, but it's quite expensive, so I didn't go for it. How did you guys deal with this problem? Do you have any good solutions? My car is over three years old and has run more than 20,000 kilometers, and this issue has come up. I think there might be a quality issue here.
The EPC light came on twice, but restarting the engine fixed it, and it hasn't appeared again. Fellow car enthusiasts, what could most likely be the issue?
There's a jerking sensation when starting at a traffic light. It didn't just start recently. Any good solutions?
Hello everyone, I have a question: My Mazda 6 had the engine light and oil light come on after shifting to neutral while waiting at a traffic light. The idle was normal, but there was no response when I pressed the gas pedal and shifted to drive. After restarting the car, everything went back to normal. I went to the dealership, but they couldn't find any error codes. Has anyone experienced something similar? How can I fix it?
Hello everyone! I have a 2022 Pioneer Edition Toyota Asia Lion, and I recently installed ambient lights. A few days later, the car battery died. Does anyone have a good solution for this issue?
Hyundai Hyundai Sonata
Hyundai SonataAED 76,000 ~ 124,000Gasoline & Hybrid
