عبدالرحمن بارزاني
عبدالرحمن بارزاني
Nov 13
Hey fellow car enthusiasts, what do you think about the dry dual-clutch? I'm considering getting the T-Roc Chasing Light Edition. Any idea how much discount is available now?
How's this car? I'm thinking of getting the Elite version. There's a cash discount of 13,000 now. 🤔
I'm considering buying a used Jeep Renegade. Today, I saw a 2017 model with a 1.4 automatic at a dealer. I've heard that dry dual-clutch transmissions often have issues. What do other car enthusiasts think? Also, the car has a noticeable tapping noise at idle. Is this a common issue with this model?
Are there any discounts available when purchasing a car right now?
If you're deciding between the MG ZS and MG HS in Europe, here are some considerations: MG ZS comes with a 1.0T engine and a 6-speed automatic transmission. However, it's a three-cylinder engine. On the other hand, the MG HS features a 1.5T engine with a dry dual-clutch transmission and is a four-cylinder. There are reports online that the MG HS might experience significant jerking issues after a year or two due to the dry dual-clutch transmission. You might want to weigh the pros and cons of each engine and transmission type based on your driving preferences and needs.
Fellow car enthusiasts, have you experienced slow shifting between the 6th and 7th gears with your 7-speed dry dual-clutch transmission? Mine doesn't shift to 7th gear even at 80 km/h and waits until it reaches 85 km/h. Is this normal?
After the company relocates, I'm thinking of getting an electric car. Can anyone tell me how much discount is currently available for the 4CT?
I was thinking about getting it back then but didn't make a move. What's the situation now? Is it still a good idea to get it, or is there a risk of it failing?
How much discount is currently available for the Kodiaq Strength Edition? Has anyone picked up their car recently?
I have a 2019 Jeep Compass 1.4T. When I put it in reverse and give it gas, there's a "thud" sound sometimes, but not always. Does anyone know what's going on? I checked with a mechanic, and they said it's normal for a dry dual-clutch transmission. Can anyone confirm this? Thanks.
How much discount is currently available for the Asian Lion? I'm considering buying one.
Volkswagen T ROC
Volkswagen T ROCEGP 1,245,444 ~ 1,862,949Gasoline & Petrol
