سعود حكم
Oct 29
Why is water dripping from the middle of the exhaust pipe of the Tango?
Whenever I accelerate my Phaeton 3.6, there's a sound like metal clanking coming from the middle section of the exhaust pipe. I can't seem to fix it. I had it checked, and there's nothing wrong with the exhaust pipe. The dealership mentioned it's a common issue. Has anyone else experienced this problem? Any solutions?
Can anyone share a picture of the mid-section exhaust pipe for a 2015 GT with a 1.5T engine? Thanks!!!
Is the four exhaust pipes at the rear of the 2023 model 95 real or fake?
4Pajero V93 chassis is leaking oil, and it's dripping onto the exhaust pipe. It needs repair.
5Is the inside of the V40 exhaust pipe black, like soot? Could it be too much carbon buildup?
6Even after changing the middle exhaust pipe, the fault light is still on. What could be the reason?
7Is the left side of the Jeep Compass exhaust pipe naturally lower, or does it need to be fixed?
8Has anyone experienced water leaking onto the passenger side from the AC? The AC drain pipe isn't clogged and it's draining water. Could it be that there's water inside the evaporator box?
9This pipe seems to be leaking oil. Does this happen to you as well? Also, what is the purpose of this pipe? Is it for exhaust gas recirculation?
10Does the exhaust pipe deformation on the 2021 Murano affect its performance?
