عبدالله طه
Nov 12
My 2021 model has run 50,000 km. It shakes when starting uphill and also when I press the gas pedal more uphill. When parked, it idles and shakes for a few seconds and then stops shaking. What's going on?
My car is automatic, and I recently noticed that when I start on an uphill, there's a kind of "bo bo" sound when I press the gas. It seems like it's coming from the transmission. But when I'm driving normally, there's no problem. Even when I hit the gas hard or drive on the highway, it's fine. It's just when I start on an uphill. 😂
When stuck in traffic, frequently braking and accelerating might lead to no response from the gas pedal. You'll need to idle forward a bit before the accelerator responds, or you can restart the engine to temporarily fix the issue.
I recently got a 2013 model 2014 Scirocco GTS. Why does the car start shaking and not move when I floor the gas pedal to start?
4Hey drivers, anyone know why my car suddenly can't accelerate while driving? I press the gas pedal and nothing happens. 😩😩 Then, when I press the brake and then the gas pedal, it accelerates. What's going on? 😎
5Has anyone with the Ariya tried the single pedal mode with economy? Have you noticed that sometimes when you start, there's no response when you press down, and it takes a few seconds before the power kicks in?
6I have a 2017 New Santana, and occasionally it won't start. If I wait a while or press the gas pedal, it starts. Can someone explain what's going on?
7Fellow car enthusiasts, have you ever experienced the brake pedal bouncing back a few times when you press it down?
8My car is a 2.0 naturally aspirated engine. When I gradually accelerate past 80 km/h, the car shakes a few times, and then it stops shaking. However, if I press the accelerator hard, this doesn't happen. I wonder what's causing this.
9Hey guys, when my Xiao 6 reaches 130 km/h, the right front wheel starts shaking. The faster I go, the more it shakes. But when I let off the gas and drop below 130, it stops. What's the issue?
10Is it normal for the 2022 Kicks to shake when accelerating from a stop?
