علي حموي
علي حموي
Dec 2
What could be causing the front left wheel to shake at low speeds, and sometimes it doesn't?
سعود ممدوح
سعود ممدوح2024-12-02 22:05
How did you determine it's the left front wheel shaking? Or is the vibration coming from that area?
عبدالرحمن صعدة
عبدالرحمن صعدة2024-12-02 12:49
Could it be the lane departure warning system? [I want to be alone]
خالد حسين
خالد حسين2024-12-02 12:40
Wheel balancing needs to be done.
نايف ميمون
نايف ميمون2024-12-02 09:24
Go check it out.
Front right wheel makes a noise at low speed.
What could be causing the steering wheel of my 2009 Lancer Sport to shake left and right while driving normally?
What could be causing the rear of a 2012 Multivan to shake at high speeds?
Changan Alsvin, ABS and anti-skid faults, diagnostic shows left front wheel speed sensor fault. I replaced it, but the lights are still on. The diagnostic still shows left front wheel speed sensor fault, but all the data streams are there. The fault can be cleared, but it comes back while driving. What should I do?
Changan Yuexiang, ABS and anti-skid fault, diagnostic shows a left front wheel speed sensor fault. I replaced it, but the lights are still on, and the diagnostic still shows the left front wheel speed sensor fault. However, all the data streams are present. The fault can be cleared, but it comes back while driving. What should I do?
I have a 2022 manual version, and I'm hearing a clunking sound when turning at low speeds. What could be causing this??? Any ideas!!!
Hey friends, when the car is running, it shakes. I did a front wheel balancing, but it still feels a bit shaky. What could be the reason?
What could be causing a clunking noise from the left front wheel on a 2013 Peugeot 508 2.3 while driving?
In the morning, when starting the vehicle and driving at low speeds, it occasionally stalls. I've already cleaned the throttle and injectors, but it still stalls sometimes. If the speed picks up, it doesn't stall. What could be the reason? 🤦‍♂️
What could cause a car to shake when starting cold?
Changan UNI-V
Changan UNI-VSAR 87,285 ~ 87,860Gasoline
