محمد أسامة
Nov 17
During the National Day holiday, I got a 2024 automatic Pioneer edition Jetta VS5 and drove it for over 900 kilometers. Now I'm facing this issue: after driving for a while, when I need to temporarily get out of the car for a few minutes, I leave the car without turning it off, with the gear in P or N position, and the auto start-stop is also turned off. However, when I get back in, the car stalls and I need to restart it. This happened twice yesterday and four or five times before. Does anyone know what might be causing this?
Comments( 9 )
Today, when I started the car, there was a "da-da-da-da" sound. After turning the engine off and starting it again, the sound was gone. This has happened twice. Not sure what the cause is.
When the self-drying function of the unit's air conditioner is activated, will it start after locking the car regardless of whether you turn off the air conditioner before turning off the engine or just turn off the engine and leave the car directly?
How can I manually turn off the air conditioning? I always have to tap on the screen to turn it off.
4Car enthusiasts: Can you please advise, do you have to be in the P gear when turning off the engine for the Changan? Can you park and turn off the engine in the N gear and then switch to P gear? Thanks!
5How to maintain your car without getting ripped off? What needs to be replaced and what doesn't?
6My 2013 manual 2.0 Peugeot 3008 stalled twice while idling with the AC on for forty minutes yesterday. Can anyone explain what the issue might be? I drove another 320 kilometers on the highway afterward, but I'm still worried.
7How do I turn off the cabin floor lights?
8Hey folks, planning a two-month road trip starting from the National Day holiday. If I get a flat tire along the way, what should I do? My Peugeot 2008 doesn't have a spare tire. What's all that stuff under the trunk for?
9If the engine isn't turned off, can the doors not be opened from the outside? I'm new to this, and it was awkward twice today. 😅
10If you leave the key in the ignition for too long without starting the car, it won't start. If the key is in the ignition for more than half a minute without turning the engine on, the key becomes stuck and you have to turn off the power and try starting the car again.
