عمر خد
Oct 27
How's the fuel consumption for a manual Jetta 5? How about the clutch distance? Is the gear shifting smooth? If anyone has driven it, please share your experience. Thanks!
Comments( 7 )
Has anyone test-driven the Volvo C40? Can you share your experience?
Is your 2018 manual KIA Pegas with 70,000 km experiencing difficulty in shifting gears, often failing to engage and grinding? It seems like the clutch isn't fully disengaging. Could this be a clutch issue or a problem with the gear linkage? How can it be resolved?
How long does it take to pick up the car after ordering? Those who have placed an order, please share your experiences.
4I want to ask about my 2019 Changan Yuexiang automatic. When I start the car cold and shift gears, it takes about 2000 RPM to change gears, like the clutch is slipping. Once the engine warms up, the shifting is normal. Do other car owners experience the same issue?
5Real LC300 3.5TT owners, please share your driving experience. [Heart]
6Have you installed electric running boards? Share some experience, please. Thanks.
7I'm looking for some guidance on how to replace the gear shift knob on a 2017 GAC GA8. If anyone knows, please share. Thanks a lot!
8How many kilometers can the clutch slave cylinder of a manual Sunny typically last? Mine seems a bit off, but the gear shifting is all normal.
9Does your Jetta automatic also have a noticeable jerk when shifting gears?
10Is there a launch edition with seat ventilation modification? Please share your experience.
