عمر مهدي
Dec 1
I want the VS5, 1.5T+6AT, without a sunroof, with a reverse camera, and tires 225/55/18.
I'm looking for advice from everyone. I want to install a reversing camera on my Mazda 2 and replace the original center console. I'm not sure if the reversing camera center console screens available online are reliable. Do you have any good recommendations?
Does the 2012 Sportage GLS have a reverse camera? Sometimes when I reverse, it shows "searching for signal," and other times the central screen doesn't change.
If you want to add a reversing camera to your 207, you can follow these general steps: 1. **Choose a Compatible Camera**: Make sure the reversing camera is compatible with your Peugeot 207 model. 2. **Purchase Necessary Equipment**: You'll need the camera itself, a compatible monitor, and any necessary wiring or connection kits. 3. **Installation**: - **Mount the Camera**: Usually on the rear license plate area or bumper. - **Run the Wiring**: Connect the camera to the monitor and power source. This often involves routing the wires through the car's interior. - **Connect to Power**: Typically, the camera is powered by the reverse light circuit, so it activates when you shift into reverse. 4. **Testing**: Once installed, test to ensure the camera activates correctly and the image displays on the monitor. If you're not comfortable doing this yourself, it's a good idea to have a professional handle the installation to ensure everything works correctly.
4I want to know if the 19 and 20 models only have the 6AT in the S trim?
5Today when I was reversing, the reverse camera suddenly showed nothing, and the screen started flickering. What's the problem here? Can anyone help me fix this?
6The reverse camera frequently goes black, and sometimes it works. How can I fix this? Looking for advice from the experts. 🙏
7I have a 2022 model Roewe RX5 MAX 1.5T. When I step on the gas in reverse, there's a "clack" sound. If I don't press the gas while reversing, there's no sound, but as soon as I do, there's a loud and very noticeable "clack" noise.
8The car's infotainment screen goes black, but when I switch to reverse, it lights up without displaying anything. [facepalm]
9I feel like the reversing camera image is not clear. Can I replace the camera individually?
10Has anyone upgraded their car's screen? 😁 I have the 2011 automatic base model and I'm just looking to see if anyone has done it before, just want to add a reversing camera.
