فهد عادل
Dec 4
Is it necessary to install soundproofing material under the hood for my manual transmission base model?
Comments( 7 )
What should I do if I can't get my hand under the hood?
I'm looking to install a roof rack on my 2009 manual Touran 2.0, which doesn't have one. Does anyone with the same model have experience to share? 😊
To determine whether your Jeep Compass is equipped with an AT (Automatic Transmission) or CVT (Continuously Variable Transmission), you can check the following: 1. **Owner's Manual**: Refer to your vehicle's owner's manual, which should specify the type of transmission. 2. **Vehicle Documentation**: Check any official documents related to the vehicle, such as the purchase agreement or service records, which might indicate the transmission type. 3. **Under the Hood**: Look at the transmission system under the hood. Sometimes the transmission type is labeled on the transmission unit itself. 4. **Vehicle Identification Number (VIN)**: Use the VIN to decode the specifications of your vehicle. Websites or services that provide detailed vehicle information based on VIN can help you identify the transmission type. 5. **Contact Dealership**: Reach out to a Jeep dealership with your VIN. They should be able to provide you with detailed information about your vehicle's transmission type. If there is conflicting information from different sources, the dealership is likely your most reliable source.
4Hey guys, how do you reset the trip meter above the total mileage on the dashboard? I have a 2011 base model, manual transmission, 1.4L hatchback.
5What kind of engine oil is suitable for a 2014 base model manual Peugeot 301?
6Is there a manual version for the new model? I hope the manual transmission is kept.
7Is the steering wheel of the 1.5 manual base model heavy?
8How's the rear space in this new manual transmission model?
9How to upgrade Gaode on the 2023 35P Manual Luxury model? How to install other software?
10Is it necessary to choose additional options for the G80, or is it not available as a base model?
