عبدالرحمن خالد
Nov 22
Is it normal for the water temperature to rise quickly, reaching 90℃ within 2 kilometers?
How many kilometers can your Mazda 2 automatic run on a full tank? My 2010 Mazda 2 can only go about 480 kilometers, can't even reach 500 kilometers...
With 90% charge, driving to 32% only gets you around 200 kilometers or so. Is that considered normal? [laugh/cry]
Is it normal that my 2011 1.5 manual Mazda 2 runs 120 kilometers on 12 liters of fuel for 100 RMB? How much does it cost per kilometer for your cars?
4I want to ask, I bought a new car and have driven 2000 kilometers, the car is overheating, and the water temperature gauge shows 90 degrees. How can I solve this issue?
5Is it normal for the water temperature of a 2015 Peugeot 508 to be around 90 degrees? [crying][crying][crying]
6Is it normal for the idle speed of a 2015 Volkswagen Touran to rise to 900 RPM when the outside temperature is below 0 degrees while the engine is warm?
7At 45,000 kilometers, there's no issue with a heavy throttle, and there's no problem with a light throttle either. But when I press the throttle slightly harder, the issue arises, especially noticeable at 2000 RPM. There's no such problem when the car is cold, but once the water temperature reaches two bars, it comes back. It's really frustrating. Any advice? 🙏🙏🙏
8How can I fix the issue of the engine noise being very loud when starting the Alto 1.0 when it's cold? The sound normalizes once the water temperature reaches 20 degrees.
9Is it normal for a 2014 Peugeot 2008 1.6 automatic to have the engine temperature rise very slowly, taking over ten minutes to reach 70 degrees? Could it be that the engine oil is too thick?
10Is it normal for the fan to frequently turn on, with a particularly loud noise, and then stop after a while, even when the water temperature is normal? Has anyone experienced this? It also happens when idling, where it turns on once every few minutes.
